Hi. I'm doing my small project. I have used Tcp-In node to connect aduino33 IOT with wifi.
sometimes when econnreset error occurs then node-red flow stops until I press enter key manually in log window. Also when i deploy flows, it just stop and stalling the operation until pressing enter key manually in log window.
Anyone help me ? What actually means pressing enter-key in log windows?
After pressing enter-key, node-red is doing suspended job right away and i can see log message.
yes. I'm sure. never come back without pressing enter-key.
I've been experiencing this for a week so I checked what I could do and I know...
Now just putting only "tcp-in node" in workspace and repeating deploy with different time gap,
Same problem happens now.
Which version of node-red are you using? Also did you see Steve's post. The safest way to check if it is this is to shrink the windows and get the terminal and node-red both on screen at once. Then you do not need to switch windows. You can then check in the browser by repeatedly deploying whether anything is hung.
