hello,
I would like to know if there is any readily available node for BLE Beacon scanner that is not using legacy scanning method which a combination of native application code for the scanning bluetooth ble beacon as this method is posing some issues on stability of the overall SW stack.
This might be known to you already about the issue when using HCItool to do a legacy scan. This is no good to newer Bluetooth module. When using hcitool & hcidump, after a short time the Bluetooth card reset and stops scanning.
Please advise.
Thank you.
regards,
rd
