Cannot browse PLC Tags with node-red-contrib-cip-st-ethernet-ip
I am using Node-Red 4.0.2 with node-red-contrib-cip-st-ethernet-ip 2.0.2.
PLC Browser is empty and hence I can not browse PLC Tags.
My Pi running Node-Red 3.1.9 can still see the PLC and be able to browse tags.
Is this an issue with Node-red 4.0.2 then?
Not likely. More likely different computer. Different OS. Different networking. Different NodeJS version.
Check and compare everything.
You are correct, Steve.
I re-installed everything from scratch and can now browse.
Below is my current setting:
Welcome to Node-RED
10 Aug 17:08:57 - [info] Node-RED version: v4.0.2
10 Aug 17:08:57 - [info] Node.js version: v20.16.0
10 Aug 17:08:57 - [info] Linux 6.8.0-40-generic x64 LE
