Hi, I have a project on BitBucket, which I clone down to RPi into the folders as required by the Projects feature, plus add the keys of the project in …/projects/.sshkeys, then start-up Node-RED, which works well.
However, in menu > Projects > Projects Settings > Settings, Git Remotes that was in the code, has additional characters, (which is not in the original project?) - that causes the History / Commit History (“Unable to access remote repository”) not to work.
I then try to delete the Git Remote (bin button), under
menu > Projects > Projects Settings > Settings > Git Remotes,
but then get this error:
An unexpected error occurred:
Error: error: could not lock config file .git/config: Permission denied fatal: could not unset 'branch.master.remote'
code: unexpected_error
Any ideas where to look?
