Cannot drag/drop nodes from palette
Hi All,
It's been a few weeks since messing around with N-R and I've hit a major problem. Whenever I try and d&d any node from the palette, it jumps up to the upper LH corner and gets "stuck" on top of the "Node-Red" logo. Next node I try to d&d replaces previous node in that spot. Nothing goes onto the flow sheet.
Fresh start:
Image 000
First attempt to drag "inject" onto flow sheet:
Image 001
Second attempt to drag "link in" onto flow sheet:
Image 002
Any logical explanation for this anomaly?
Russ
Can you open the javascript console of your browser and check for any errors?
I would if I knew how to. :face_with_raised_eyebrow: I did go to my Pi and check it directly using the Pi's Chrome browser, N-R works fine there. I am (and have been) using a Win7x64 laptop with FF v82.02 to do my tinkering as it hurts my back to sit at the desk where the Pi is located.
I had previously added a userchrome.css file to my Win FF to make some appearance changes. Undid that and N-R is still misbehaving. The only other change I can think of is FF had auto-updated from 81.0 sometime in the past few days...
Russ
Press F12
Well, that's interesting:
JQMIGRATE: Migrate is installed, version 3.3.0 vendor.js:4:711
Node-RED: 1.1.2 red.min.js:16:17059
Versions red.min.js:16:17095
jQuery 3.5.1 red.min.js:16:17130
jQuery UI 1.12.1 red.min.js:16:17163
ACE 1.4.3 red.min.js:16:17201
D3 3.0.3 red.min.js:16:17232
Projects disabled red.min.js:16:8560
Error in parsing value for ‘contain’.  Declaration dropped. 192.168.1.14:1880:1:1710
Error in parsing value for ‘contain’.  Declaration dropped. 192.168.1.14:1880:1:2230
Error in parsing value for ‘contain’.  Declaration dropped. 192.168.1.14:1880:1:6403
Error in parsing value for ‘contain’.  Declaration dropped. 192.168.1.14:1880:1:6527
Error in parsing value for ‘contain’.  Declaration dropped. 192.168.1.14:1880:1:6619
Error in parsing value for ‘text-align’.  Declaration dropped. 192.168.1.14:1880:57:21
Expected ‘none’, URL, or filter function but found ‘Alpha(’.  Error in parsing value for ‘filter’.  Declaration dropped. jquery-ui.min.css:7:516
Expected ‘none’, URL, or filter function but found ‘alpha(’.  Error in parsing value for ‘filter’.  Declaration dropped. jquery-ui.min.css:7:12176
Expected ‘none’, URL, or filter function but found ‘Alpha(’.  Error in parsing value for ‘filter’.  Declaration dropped. jquery-ui.min.css:7:18297
Expected ‘none’, URL, or filter function but found ‘Alpha(’.  Error in parsing value for ‘filter’.  Declaration dropped. jquery-ui.min.css:7:18447
Expected ‘none’, URL, or filter function but found ‘Alpha(’.  Error in parsing value for ‘filter’.  Declaration dropped. jquery-ui.min.css:7:18522
Expected ‘none’, URL, or filter function but found ‘Alpha(’.  Error in parsing value for ‘filter’.  Declaration dropped. jquery-ui.min.css:7:29046
Unknown property ‘-moz-osx-font-smoothing’.  Declaration dropped. font-awesome.min.css:4:662
Error in parsing value for ‘width’.  Declaration dropped. style.min.css:16:6455
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:541
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:8705
Unknown pseudo-class or pseudo-element ‘-ms-input-placeholder’.  Ruleset ignored due to bad selector. style.min.css:24:10735
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:19480
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:28232
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:28286
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:30512
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:31159
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:31181
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:31218
Expected declaration but found ‘*’.  Skipped to next declaration. style.min.css:24:31348
Error in parsing value for ‘padding’.  Declaration dropped.
This is just after loading the page, no user interactio at all. I have no idea what I'm looking at, perhaps some knowledgeable soul will...
Russ
OK, out of frustration I deleted my entire flow all the way back to what the base startup looks like. My project was for cr@p anyways. Did a full deploy on the empty shell, closed browser, reloaded N-R and it is still doing the same thing. I tried my old favorite FF v56.0, same thing. Apparently, something on this particular computer has changed. The only thing I've manually updated was Flash to 32.0...
Error in parsing value for ‘padding’.  Declaration dropped. style.min.css:24:109387
These console errors are from the "clean sheet" N-R with zero flows or nodes deployed. Are they indicating problems with N-R or conflicts with some other program or ? ? ?
Russ
Have you cleared the browser cache?
and do you have any browser plugins installed ? maybe try with them disabled...
First thing I tried, no joy there.
Wooohooo, that was it! Now to narrow down the culprit.
Thanks!
Russ
FWIW, it was the add-on "No Scroll" causing the problem. Disabling fixed it.
Russ
