Google translate
Bonjour Hello
Voici le projet que je veux utiliser :
Here is the project I want to use :
Après avoir installé tous les nodes est adapter certaine partie du programme.
After having installed all the nodes is to adapt certain part of the program.
Je n’arrive pas à comprendre comment faire pour lire les sondes PH et EC atlas Scientific.
I cannot figure out how to read the atlas Scientific PH and EC probes.
Quand je fais un I2C scan je trouve bien PH 99=0x63, EC 100=0x64, Temp 102=0x66.
When I do an I2C scan I find PH 99 = 0x63, EC 100 = 0x64, Temp 102 = 0x66.
Dans le flow, Node Edit exe node il faut rentrer une commande spéciale ????
In the flow, Node Edit exe node you have to enter a special command ????
Je suis un peu perdu.
I am a little lost.
Equipment:
Merci pour votre aide. Thanks for your help.
flows (7).json (16.3 KB)
I had this issue. I found a Fix that I describe in an entry that I made in this thread on May 1, 2020.
https://discourse.nodered.org/t/aquarium-controller-raspberry-pi-4b-node-red-atlas-scientific-i2c-devices-ncd-i2c-relay-board/25839
Scroll down until you see my entry for May 1, 2020.. and I describe using the i2c nodes to read Atlas-Sci EZO circuits.
Unfortunatley, the thread is closed becuase I did not update the information in a timely fashion, but the information is still relevant.
Colin
3
The thread can be re-opened if you think that there is stuff to add that will make it more useful in the future.
