Can't instal SQLite on node-red
My Node-red is working fine on my RPI2, but I can't install SQLite!
Here is what I do and what I get.
pi@RPI2:~/.node-red $ sudo npm install node-red-node-sqlite
npm WARN node-red-project@0.0.1 No repository field.
npm WARN node-red-project@0.0.1 No license field.
+ node-red-node-sqlite@0.3.5
updated 1 package and audited 1017 packages in 40.703s
found 0 vulnerabilities
I tried installing it from the node-red "manage pallet" tab.
No errors are returned.
Can anyone help me resolve this issue?
I've also upgraded to the latest versions of everything including n and npm;
sudo n latest
sudo npm install -g npm
Hi @PicoPi
You should not use sudo when installing modules in ~/.node-red as it will muck up your file permissions.
The output you've shared shows a completely successful install of the sqlite module.
Have you restarted Node-RED?
Have you checked the Node-RED log on startup to see if there are any error messages related to the module?
Thanks for the quick rely.
I've rebooted the Pi a couple of times.
where can I check for the log file?
The reason I used sudo was that I got a bunch of permission errors
Which was telling you that you have a larger issue. You most likely need to save you flows, uninstall Node-RED (and possibly Node.JS), certainly remove all your global npm packages and rename your userDir folder (probably ~/.node-red).
Then carefully follow the installation instructions.
Only Node-RED itself needs to be installed globally in a standard installation. If you get errors when installing nodes from the palette, come back to us with the errors and we can help you sort it out.
It was working fine until I decided to install sqlite.
I don't have the knowledge to do all you suggested.
I have a backup of my SD card. I'll revert back to it.
Thanks.
once reverted you should be able to do
cd ~/.node-red
npm i --unsafe-perm node-red-node-sqlite
Sorry for the late response.
This problem you are having is a very common issue.
Please check this answer: Sqlite doesn t work after update about how to install the SQLite node on a Rpi
Thanks for the reply.
I managed to install it from the command line. It does take a long time, but It showed up under "Storage" nodes after that.
Just to make sure and experiment a bit more, I then went back to a fresh install of Rasbian, and this time, installed it from inside Node-Red using "Manage Pallets".
It also worked but took a long time.
Thanks again for the heads up.
~A happy camper
