As i wrote in the title, i have installed from the pallet lots of diffent thing but just this node is giving me problems. I have seen some solutions online however i'm using this particular application (ctrlx) where i have just nodered/ the manage pallete and i can't seem to access any console or anyting similar, this is the log when i try to install it, thanks you ( i had to had spaces in some links to be able to make this post):
2024-02-12T17:04:30.748Z Install : node-red-contrib-chart-image-1.2.0.tgz
2024-02-12T17:04:30.110Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict /var/snap/ctrlx-node-red/732/solutions/activeConfiguration/node-RED/nodes/node-red-contrib-chart-image-1.2.0.tgz
2024-02-12T17:04:31.484Z [err] npm
2024-02-12T17:04:31.486Z [err] WARN config production Use `--omit=dev` instead.
2024-02-12T17:04:32.132Z [err] (node:2786) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
2024-02-12T17:04:32.132Z [err] (Use `node --trace-warnings ...` to show where the warning was created)
2024-02-12T17:05:42.397Z [err] npm ERR! code EAI_AGAIN
2024-02-12T17:05:42.398Z [err] npm
2024-02-12T17:05:42.398Z [err] ERR! syscall getaddrinfo
2024-02-12T17:05:42.398Z [err] npm ERR! errno EAI_AGAIN
2024-02-12T17:05:42.402Z [err] npm ERR! request to h ttps://registry.npmjs.org/chart. js failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
2024-02-12T17:05:42.411Z [err]
2024-02-12T17:05:42.411Z [err] npm ERR!
2024-02-12T17:05:42.411Z [err] A complete log of this run can be found in:
2024-02-12T17:05:42.411Z [err] npm ERR! /root/snap/ctrlx-node-red/732/.npm/_logs/2024-02-12T17_04_31_392Z-debug-0.log
2024-02-12T17:05:42.428Z rc=1
2024-02-12T17:08:47.082Z Install : node-red-contrib-chart-image-1.2.0.tgz
2024-02-12T17:08:46.339Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict /var/snap/ctrlx-node-red/732/solutions/activeConfiguration/node-RED/nodes/node-red-contrib-chart-image-1.2.0.tgz
2024-02-12T17:08:47.832Z [err] npm
2024-02-12T17:08:47.836Z [err] WARN config production Use `--omit=dev` instead.
2024-02-12T17:08:48.494Z [err] (node:2835) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
2024-02-12T17:08:48.494Z [err] (Use `node --trace-warnings ...` to show where the warning was created)
2024-02-12T17:09:58.683Z [err] npm ERR! code EAI_AGAIN
2024-02-12T17:09:58.684Z [err] npm
2024-02-12T17:09:58.684Z [err] ERR! syscall getaddrinfo
2024-02-12T17:09:58.684Z [err] npm ERR! errno EAI_AGAIN
2024-02-12T17:09:58.688Z [err] npm ERR! request to h ttps://registry.npmjs.org/chart. js failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
2024-02-12T17:09:58.697Z [err]
2024-02-12T17:09:58.698Z [err] npm ERR! A complete log of this run can be found in:
2024-02-12T17:09:58.698Z [err] npm ERR! /root/snap/ctrlx-node-red/732/.npm/_logs/2024-02-12T17_08_47_671Z-debug-0.log
2024-02-12T17:09:58.715Z rc=1.
