If it isn't that then exactly what happens when you try to open it in the browser?
Also have a look in the browser Developer Console to see if there are any errors.
I am trying to open 127.0.0.1:1880 on the same machine where node-red is running and I've always done it like that.
my browser just tries to load the site. It's been like this:
for an hour or so. I also tried with multiple browser and no luck. Can't have a look in browser developer terminal since it can't even load the website
The whole message in Terminal:
Welcome to Node-RED
16 Jan 12:58:03 - [info] Node-RED version: v1.2.7
16 Jan 12:58:03 - [info] Node.js version: v14.13.0
16 Jan 12:58:03 - [info] Windows_NT 10.0.19041 x64 LE
16 Jan 12:58:04 - [info] Loading palette nodes
16 Jan 12:58:05 - [info] Worldmap version 2.6.0
16 Jan 12:58:05 - [info] Dashboard version 2.23.4 started at /ui
16 Jan 12:58:05 - [info] Settings file : \Users\Saskia\.node-red\settings.js
16 Jan 12:58:05 - [info] Context store : 'default' [module=memory]
16 Jan 12:58:05 - [info] User directory : \Users\Saskia\.node-red
16 Jan 12:58:05 - [warn] Projects disabled : editorTheme.projects.enabled=false
16 Jan 12:58:05 - [info] Flows file : \Users\Saskia\.node-red\flows_LAPTOP-J60STHNJ.json
16 Jan 12:58:05 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
16 Jan 12:58:05 - [info] Starting flows
16 Jan 12:58:06 - [info] [ui_worldmap:50e925f4.23c04c] started at /worldmap
16 Jan 12:58:06 - [info] [ui_worldmap:new] started at /newmap
16 Jan 12:58:06 - [warn] [telegram command:Mistkuebel start] bot not initialized.
16 Jan 12:58:06 - [warn] [telegram command:Mistkuebel getupdates] bot not initialized.
16 Jan 12:58:06 - [warn] [telegram sender:c9e943d3.65f3a] bot not initialized.
16 Jan 12:58:06 - [warn] [telegram command:Mistkuebel erstelleMistkübel] bot not initialized.
16 Jan 12:58:06 - [warn] [telegram sender:bb969782.90a878] bot not initialized.
16 Jan 12:58:06 - [info] Started flows
In that case try localhost:1880 and if that also doesn't work then I suspect node-red may be stuck in a loop of some sort. Stop node red then start it again using node-red --safe
which will start the editor without starting the flows.
If that does it then what were you doing when it stopped working? Something with MQTT possibly, or feeding values back into the front of dashboard switches or something similar.
Edit Also I asked what you see in the developer console.
It is quite possible in your last modification (or a bug in your flows has surfaced) that has caused a loop & preventing transmissions occurring due to being bogged down. Try start in safe mode again and disabling (temporarily) anything that looks like a loop or an MQTT out node, then work from there.
MQTT loops can be harder to find but in basic terms, if you subscribe to a topic that you later update & send to mqttout node, you can create an infinite loop.
Open another MQTT client, such as mosquitto_sub or MQTT Explorer, subscribe to "#" and see if something is clobbering it.
That confuses me slightly, I understood it was the editor that was hanging, not the dashboard. If you deploy are you able to carry on editing flows in the editor?
