I cannot open node red. Here is the message appears:
RizkiMF@Rizki-MF-MBP ~ % node-red
21 Apr 17:04:58 - [info]
Welcome to Node-RED
21 Apr 17:04:58 - [info] Node-RED version: v3.1.2
21 Apr 17:04:58 - [info] Node.js version: v16.20.1
21 Apr 17:04:58 - [info] Darwin 21.6.0 x64 LE
21 Apr 17:04:59 - [info] Loading palette nodes
*** connect-system function called
ipc initialize
21 Apr 17:04:59 - [warn] [RED.events] Deprecated use of "nodes-started" event from "/Users/RizkiMF/.node-red/node_modules/connect-nodes/ipc/ipc.js:66:20". Use "flows:started" instead.
21 Apr 17:04:59 - [warn] [RED.events] Deprecated use of "nodes-stopped" event from "/Users/RizkiMF/.node-red/node_modules/connect-nodes/ipc/ipc.js:67:20". Use "flows:stopped" instead.
serial2-ajax-gateway initialize
serialport-gateway initialize /dev/ttyS2
http-gateway initialize
modbus-rs485-gateway initialize
serial1-connect-gateway initialize. Block type: undefined. Block version: undefined
serialport-gateway initialize /dev/ttyS1
21 Apr 17:05:00 - [info] Dashboard version 3.2.0 started at /ui
on error
21 Apr 17:05:00 - [warn] ------------------------------------------------------
21 Apr 17:05:00 - [warn] [connect-nodes/CONNECT system] Error: EACCES: permission denied, mkdir '/etc/connect-nodes/zigbee'
21 Apr 17:05:00 - [info] Settings file : /Users/RizkiMF/.node-red/settings.js
21 Apr 17:05:00 - [info] Context store : 'default' [module=memory]
21 Apr 17:05:00 - [info] User directory : /Users/RizkiMF/.node-red
21 Apr 17:05:00 - [info] Projects directory: /Users/RizkiMF/.node-red/projects
21 Apr 17:05:00 - [warn] No active project : using default flows file
21 Apr 17:05:00 - [info] Flows file : /Users/RizkiMF/.node-red/flows.json
21 Apr 17:05:01 - [info] Server now running at http://127.0.0.1:1880/
21 Apr 17:05:01 - [warn]
your credentials.
21 Apr 17:05:01 - [info] Starting flows
21 Apr 17:05:01 - [error] [mqttdb in:e81d72bbcaa20b27] missing broker configuration
21 Apr 17:05:01 - [info] Started flows
21 Apr 17:05:02 - [info] [mqtt-broker:af6fb6b65ea2fa1f] Connected to broker: mqtt://broker.mqtt-dashboard.com:1883
on error
on error
on error
on error
on error
on error
Can anyone help to solve this problems?
