I have installed the following node into my working NR server (v3.1.3) via Palette -> Install, but it doesn't show up in the list of available nodes ot use in workflow. Restarted NR and the host server, refreshed browser, still not there. Any ideas why not?
Search available node yields no result:
Aslo tried running this in the .NodeRed folder, but still doesn't appear:
sudo npm install node-red-contrib-device-monitor
Colin
1 April 2024 15:42
2
Welcome to the forum @efelmer
What hardware/OS are you using?
Do you see anything in the browser developer console if you refresh the page?
If not then show us what you see if you restart node-red in a command window. It should start with the Welcome to Node-red message.
Colin
1 April 2024 15:51
3
It appears that the node does not work any more.
opened 08:38AM - 03 Sep 23 UTC
After installing the add-on (via Manage Palette) it does not appear in the palet… te.
In Manage Palette node device-monitor has a gray mark (not active?)
What group name is used for it in the palette (this information is missing in the documentation)?
It is always worth checking for issues on a node's github page if you have problems.
Hi Colin,
Raspberry Pi 4B:
PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
NAME="Raspbian GNU/Linux"
Nothing obviously failing in console on page refresh.
Ah, I had a look on NPM site and github, but missed the issue. As they say in the UK advert, should have gone to Specsavers Thx Colin.
