Manage palette not found
I'm running my node-RED but it does not show manage palette and some other components anyone who knows how to resolve this please help.
First off, it would be helpful if you let us know
  1. what platform and device is NR running
  2. what version of NR and node.js are you running (you can find this in the startup log
Also how did you install node-red?
In a command line terminal, what does this command show
npm -v
Device: Raspberry Pi 3B+
npm version: 8.19.2
node-red: v16.18.1
God-Did@God-Did:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://169.254.216.63:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
[sudo] password for God-Did:
Sorry, try again.
Starting as a systemd service.
23 Nov 10:48:26 - [info]
Welcome to Node-RED
23 Nov 10:48:26 - [info] Node-RED version: v3.0.2
23 Nov 10:48:26 - [info] Node.js version: v16.18.1
23 Nov 10:48:26 - [info] Linux 5.10.103-v8+ arm64 LE
23 Nov 10:48:31 - [info] Loading palette nodes
23 Nov 10:48:42 - [info] Dashboard version 1.0.2 started at /ui
23 Nov 10:48:55 - [info] Worldmap version 2.31.0
23 Nov 10:48:55 - [info] Node-RED Dashboard not found - ui_worldmap not installed.
23 Nov 10:48:56 - [warn] ------------------------------------------------------
23 Nov 10:48:56 - [warn] [node-red-contrib-node-webcam/node-webcam] Error: Cannot find module 'webcam'
Require stack:
  • /home/God-Did/.node-red/node_modules/node-red-contrib-node-webcam/node-webcam.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/index.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/index.js
  • /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/index.js
  • /usr/lib/node_modules/node-red/lib/red.js
  • /usr/lib/node_modules/node-red/red.js
    23 Nov 10:48:56 - [info] Settings file : /home/God-Did/.node-red/settings.js
    23 Nov 10:48:56 - [info] Context store : 'default' [module=memory]
    23 Nov 10:48:56 - [info] User directory : /home/God-Did/.node-red
    23 Nov 10:48:56 - [warn] Projects disabled : editorTheme.projects.enabled=false
    23 Nov 10:48:56 - [info] Flows file : /home/God-Did/.node-red/flows.json
your credentials.
23 Nov 10:48:56 - [warn] Encrypted credentials not found
23 Nov 10:48:56 - [info] Server now running at http://127.0.0.1:1880/
23 Nov 10:48:56 - [info] Starting flows
node-red: v3.0.2
node.js: v16.18.1
It looks like you marked the thread solved. But at any rate, you have a couple of issues that show up in the log which may or may not effect the palette issue ou should fix those.
1- 23 Nov 10:48:55 - [info] Node-RED Dashboard not found - ui_worldmap not installed.
you need to install node-red-dashboard
2- 23 Nov 10:48:56 - [warn] [node-red-contrib-node-webcam/node-webcam] Error: Cannot find module 'webcam'
If you look at the information about the node (something you should make a habit of doing befor installing a node) node-red-contrib-node-webcam (node) - Node-RED You will see it has an extra step
Additionally you have to install on the Raspberry Pi
You have to install fswebcam by following command.
sudo apt install fswebcam
If you are using the default path - the /home/pi/Pictures will be used.
So you should do that also.
Fix those, stop and restart NR and see if the 'Manage Palette' option works
errr - no you don't need to install it... it's just info saying that particular ui node won't work unless you do... - the rest of the worldmap nodes will work just fine without the dashboard...
