Change Node - access Array Object
Guys,
I have a global Object with array elements in there - the number of elements varies dependant on the time.
Is there a way in a Change Node to access the last element in an array ??
I am essentially trying to grab some dynamic info and put it out to a log file.
Here is a picture of the object/array in question
Currently Amber.CurrentBids has 4 elements in the array - but at the 1/2 hour and hour this gets reset to 0 and then the elements filled every 5 minutes.
So in a change node i want to set (say) msg.Amber5MinBid to global.Amber.CurrentBids."Last Array Value"
Anyway to do this or is it better with a function node ?
Craig
I have just done some messing around with jsonata instead of the global set
$globalContext("Amber.CurrentBids".[-1])
Appears from online reading that it should do it but does not
Also tried
$globalContext("Amber.CurrentBids.[-1]")
No good either
but if i try
$globalContext("Amber.CurrentBids.0")
that works fine.
So i am wondering if we do not support this in NR in Jsonata ?
Craig
what about
$globalContext("Amber.CurrentBids")[-1]
Yep that got it - thanks for the pointer !!
Craig
