Changing the default date format
This should be an easy question from a new user.
The selected date shows up in the UI for the date picker node.
I'm using the date picker node and some place I changed the default date format but I cant remember where.
It was mm/dd/yyyy and I want the standard yyyy/mm/dd but I typed it wrong and got yyyy/mmdd.
I have no problem formatting the date the is produced but it is showing in the UI in some default format.
Does anyone know where this is, I've seen it a couple of times when I didn't pay any attention and now I cant find it.
It seems like it should be in user setting or the properties of the node but its not there.
thanks for your help.
No problem - if that working for you just mark it a solution to help others looking.
No problem, I'm learning how to work in this environment. Thanks for pointing that out to me.
