Hello!
Whats the simplest route?
I'm wanting a manually (time settable via chatbot) timer switch to pass payload message thru one output to trigger thermostat to a specific temp ie: 19*C.
Then trigger a second output after a manually set time to send the payboad to reset the thermostat to its programmed schedule.
Chatbot will ask till what time do you want the switch on till? reply ie: 10pm
Example flow here:
