Not sure if this is the discourse site or nodered.org
Good point @ukmoose - have renamed the category to just âfeedbackâ and updated the description. Itâs intended to be feedback on the discourse forum and how weâve got them setup etc.
Links (except âhelpâ) at the top of the forum page go to nodered.org, but there is no link from nodered.org back to discourse.
BTW, I tried to enter the actual link instead of âdiscourseâ and got an error message, âSorry, new users can only put 2 links in a post.â Whatâs with that?
Yes, weâre in the process of opening it up slowly⌠as we do the link will be put on the home page to link back here. I think it will just be a help link on the top bar
âSorry, new users can only put 2 links in a post.â What's with that?
It's a default setting of discourse to discourage automated bot sign-ups that start spamming links. One of the many config options discourse provides that we'll tune over time based on feedback.
All looks fairly good so far. There are certainly things about discourse I donât like - Iâve only just started using it myself having joined the Hugo discourse to get some help converting my blog from self-hosted WordPress to Hugo/Netlify. I takes a little getting used to but it is pretty decent over all.
One minor point, the top bar is a little large, especially on a high-res laptop screen. And particularly when the Node-RED top bar is also showing. Could that be reduced in size slightly?
Actually, maybe ignore me since I was actually zoomed in slightly. So perhaps not quite the issue I thought it was.
It would be nice to have topic specific Categories around different types of uses for the system. i.e. a Home Automation forum so we can post specific use cases and 3rd party integrations around home automation.
Also, would be helpful if youâd turn on the tagging functionality in Discourse to make it easier to group topics for later searching. Hereâs a Discourse based forum I used to participate in that I thought did a good job of using a combination of categories and tags - https://community.openhab.org/latest
Thanks for getting this started. Much better than Google Groups.
Tagging is nice.
Could I also suggest having something like a âHints & Tipsâ category? This works well - for example in the Hugo Discourse - encouraging people to contribute their favourite hints not just asking questions.
Keep the ideas coming. What we have now is not set in stone. But likewise we arenât going to lob in everything on day 1 (or 2). Certainly tags will probably be added, as will more categories.
I do agree with Julian that a good bit of space is lost a the top of the page for headers â but thatâs minor.
The one behavior Iâm missing (different from the google groups site) is the navigation element at the top of the list of latest posts. Usually I would start with the oldest of the say 25 ânewâ posts, and click backward through them in time order, until I get to #1 using the line at the top:
25 of 99+
Having something similar to this in the header would be ideal, i think.
If I go to the "latest" view I get a red line like
which is fairly easy to work up from ?
And then at the bottom of an individual thread I get links to both x new posts or latest, so yes it's different but sort of there.
very nice!
some thoughts:
- Categories: Although I think that too many categories are not good either, I think a few more could make sense. The one I am missing is
- Node development. This category would be both for questions regarding the development of new nodes and also to share/discuss best practices. Or is this included in the âdevelopmentâ category (I remember in Slack that the dev channel should be for node-red core development only)
- Header: As Julian said, those two headers are a bit weird. Especially on mobile, the experience maybe could be improved. Specifically, if I press the âbackâ button, then both headers will appear, instead of only the red one from discourse. This makes navigating a bit hectic. An other issue, if I scroll down on mobile, then often both headers completely disappear, after one or two seconds, the discourse header appears again. Is it possible to always âretractâ the header when scrolling?
Iâm fairly comfortable with using General for nodes, and flows and general application usage type development. (Otherwise what goes in general ?). I do think we may want an Installing/Upgrading category for more the running side of operations.
My view on categories: I think there should be a category for people seeking help with NodeJS or JS coding. It seems to me that there are a lot of posts about JS-programming. These questions arrive here because people are using node-red in the first place. Although those questions should probably be more suited for places like stackoverflow or any JS-learning website, they have nonetheless their place here but maybe in a category of their own. (BTW, I must thank everybody on this community for being so nice & patient, answering sometimes very basic JS questions, totally unrelated to NR).
I think there is a place for 'creating nodes' as a distinct category - it is a bit more specialised and not in the general 'how do I use Node-RED to do X' type topic.
We are a bit limited here. We want the NR header to keep it consistent with other parts of the site (there are 5 distinct web apps all under nodered.org and its subdomains).
Some of the hiding/showing behaviour is just how Discourse does it. I quite like the fact the headers hide themselves when you start scrolling to give you more space - I understand it won't be to everyone's taste.
Whether we can shrink the black NR header a bit just for this site when viewed on mobile... I'll have a play.
Hmm, not so sure. We simply don't have the resources to become a general JS/Node support forum. Having a category invites those questions rather than allowing us to point at more focussed resources on those topics (such as StackOverflow, MDN etc).
Well, I see what you mean/fear Nick, but itâs already a reality, IMHO, I see many posts more related to JS than to NR and the community seems ready enough to answer these questions. Maybe a more general âhow do I do this ?/how-toâ category ? It could encompass JS-coding but also JSON, JSONata and other side âtechnologiesâ not directly related to NR ? This is all to avoid the âGeneralâ category to be an âunclassifiedâ category or worse an all-purpose/catch-all category when some topics could be more categorized âŚ
------ Message dâorigine ------
I think there do need to be some more categories, Iâm just not sure what they are yet.
Right - this topic started with @ukmoose asking us to clarify the purpose of this Category. It wasnât intended to become an endless thread of suggestions which then get lost. As weâve thoroughly dealt with Markâs original question Iâm going to:
- retitle this topic so its less inviting to more suggestions
- close the topic as it doesnât need any more replies to Mark
- start a new topic for âcategory suggestionsâ
Thanks for all the feedback so far.
