Clipping of Charts
I am having trouble maintaining some distances from the axes while plotting line graph. I have seen that there is an option called clip in charts.js documentation which will keep the plotting off graph raised to a particular point above the axes. The problem is that I have no able to deploy it correctly. This is my msg.ui_control paylod.
    "options": {
        "clip": {
            "left": 10,
            "top": 15,
            "right": 10,
            "bottom": -15
        "elements": {
            "line": {
                "borderWidth": 5,
                "fill": false
            "point": {
                "radius": 8
I do believe that the placement of the clip details could be the problem here and so my graph looks like this.
I want it to look like the below
You can see that the graph is not touching any axes.
What is the data that is creating the flow?
The data looks like below.
        "series": [
            "Total Returns"
        "data": [
                21,
                29,
                25,
                25,
                20,
                27
        "labels": [
            "Jan",
            "Feb",
            "Mar",
            "Apr",
            "May",
            "Jun"
This data does not seem to be reflected in the chart images you posted
do you mean that that is the msg.payload being sent to a ui-control node?
It might be clearer if you were to provide your flow
This should give you the idea of flow of payload.
[{"id":"672b26ecea3c997d","type":"change","z":"ea287ec.ff1148","name":"size","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"options\":{\"clip\":{\"left\":20,\"top\":50,\"right\":20,\"bottom\":-50},\"elements\":{\"line\":{\"borderWidth\":5,\"fill\":false},\"point\":{\"radius\":8}}}}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":3620,"wires":[["e57199372e1aeee4"]]},{"id":"e57199372e1aeee4","type":"ui_chart","z":"ea287ec.ff1148","name":"Chart","group":"d08eb194.4f60d","order":7,"width":16,"height":9,"label":"Mutual Fund Return % History","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":true,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"30","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#d1001f","#f10404","#d66400","#025f02","#130557","#9e0557","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":570,"y":3620,"wires":[[]]},{"id":"4468935ca99051a3","type":"inject","z":"ea287ec.ff1148","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"series\":[\"Total Returns\"],\"data\":[[21,29,25,25,20,27]],\"labels\":[\"Jan\",\"Feb\",\"Mar\",\"Apr\",\"May\",\"Jun\"]}]","payloadType":"json","x":260,"y":3620,"wires":[["672b26ecea3c997d"]]},{"id":"d08eb194.4f60d","type":"ui_group","name":"Mutual Fund Investment History","tab":"a9a5b115d50d9ca1","order":1,"disp":false,"width":"16","collapse":false},{"id":"a9a5b115d50d9ca1","type":"ui_tab","name":"Mutual Fund Investment History","icon":"dashboard","disabled":false,"hidden":false}]
Not all chart.js options will apply to the ui-chart node. The ui-chart node dynamically builds the x and y axis'. for example if you have a value of 19, the y-axis will begin at 0, but if your lowest entry is 20, the y-axis will start at 20. If you go into your sample flow and change a valaue to 19, you will see the change.
For your x-axis starting with a ' ', will push Jan over on the x-axis giving you space.
You can create graphs using chart.js with a ui-template node (here is an example creating a bubble chart using chart.js: EXAMPLE: How to create a Bubble chart (can be used as basis for scatter plot too) (flow) - Node-RED) or use the node-red-contrib-chartjs node (I have no experience with it)
Here is your flow with the added " " and a data of 0 added.
[{"id":"cf654b95d23fcd66","type":"change","z":"a3faa9967eaf2dcb","name":"size","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{\"options\":{\"clip\":{\"left\":20,\"top\":50,\"right\":20,\"bottom\":-50},\"elements\":{\"line\":{\"borderWidth\":5,\"fill\":false},\"point\":{\"radius\":8}}}}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":320,"wires":[["48206c8bed5e60d8"]]},{"id":"48206c8bed5e60d8","type":"ui_chart","z":"a3faa9967eaf2dcb","name":"Chart","group":"d08eb194.4f60d","order":7,"width":16,"height":9,"label":"Mutual Fund Return % History","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":true,"ymin":"15","ymax":"35","removeOlder":1,"removeOlderPoints":"30","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#d1001f","#f10404","#d66400","#025f02","#130557","#9e0557","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":610,"y":320,"wires":[[]]},{"id":"d2004b5a7401348b","type":"inject","z":"a3faa9967eaf2dcb","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"series\":[\"Total Returns\"],\"data\":[[0,21,29,25,25,20,27]],\"labels\":[\" \",\"Jan\",\"Feb\",\"Mar\",\"Apr\",\"May\",\"Jun\"]}]","payloadType":"json","x":300,"y":320,"wires":[["cf654b95d23fcd66"]]},{"id":"d08eb194.4f60d","type":"ui_group","name":"Mutual Fund Investment History","tab":"a9a5b115d50d9ca1","order":1,"disp":false,"width":"16","collapse":false},{"id":"a9a5b115d50d9ca1","type":"ui_tab","name":"Mutual Fund Investment History","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Here you have fixed the max and minimum y axes for the chart which in my application wont be feasible, as the range can also be negative and also way high. I dont see a way to dynamically change the max and minimums also.
Other than building the chart using the ui-template I’m not sure what you could do
you should be able to set the max and min via a ui_control message - https://github.com/node-red/node-red-dashboard/blob/master/config-fields.md
