Color Selection Problem on Safari
Hi everyone,
I’m a beginner in Node-RED and recently decided to create my own custom dashboard theme. However, I’ve run into an issue: I can’t select or change colors anywhere in the dashboard settings where it should be possible to modify them.
To troubleshoot, I tried accessing the Node-RED dashboard in a different browser. My Node-RED instance is running locally using Docker, and I’ve been primarily working in Safari. After encountering the issue in Safari, I switched to Chrome to test if the problem persisted. Surprisingly, everything worked fine in Chrome—I was able to select and change colors without any issues.
Now I’m wondering: what could be causing this issue in Safari, and how can I fix it so that I can work seamlessly in that browser? Has anyone else experienced something similar?
Thanks in advance for your help!
first screenshot from safari. The color picker. After choosing any color, there are no changes.
second screenshots from chrome. The color picker. After choosing any color, new color is applied.
