ComfoAir connection via USB by ID
i have the node-red-comfoair node installed and i really like it!!!
The only thing is, that whenever there is a restart it could be that the comfoair is using a different USB port and i need to go to the code and change it,....
It would be so cool to implement the connection by usb ID to make sure it's alway working correct.
Maybe someone (@coolchip ) of you has an Idea or maybe can implement that in the node.
Thanx really a lot for this nice implementation!
Kind regards,
Mark
If you use a Raspberry Pi, you might look at PersistentUSBDevices - Domoticz
For other OS, you may google for persistent USB.
Regards
Hi why not use an MQTT node and assign the COM port dynamically?
If you are using something like a Pi or a Linux based OS then, with the device unplugged, run
ls /dev/serail/by-id
then plug the device in and run it again. If you see a new entry, possibly something like
ls /dev/serial/by-id
usb-FTDI_USB__-__Serial-if00-port0
then you can use that to identify the device, if the node will accept it, so in this case it would be
/dev/serial/by-id/usb-FTDI_USB__-__Serial-if00-port0
Jiiiiiiiha! many many thx for that hint! Works perfect!!!!!
While we are talking about that nice NODE,... is there also a way to get all the other Parameters aut of the "P" Menus also?
