I know how to change topics with the change-node, and how to compare their payloads afterwards. But I want to use the function-node for this. I have this topic: "home/auto/beschattung"
and want to replace it with "abesch" and keep the payload as it is.
Sounds very simple, but I cannot find a solution.
msg.topic = ‘abesch’
Thank you. But this is not working when you have more than one flow. For example:
msg.topic = "power";
node.status({fill:"red",shape:"dot",text:"Leistung:" + msg.payload.power});
gives an 'undefined' in the node status (when coding just 'msg.payload', the node status is OK). But I will calculate and display different payloads.
Without seeing the rest of the code I can’t comment on what you are doing.
Reading between the lines, it sounds like you aim is to get multiple values from different sources into 1 message so that you can compare values.
On that assumption, consider this:
- MQTT in 1 -
home/auto/beschattung/power - MQTT in 2 -
home/auto/abesch/power
Pass these to a join node, set for 2 elements & then you will get both values in one message. Then you will see both values from the 2 sources in one msg.payload.xxx.
Here are some canned texts to help you:
Joining messages
See this article in the cookbook for an example of how to join messages into one object.
Getting data from the msg
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
Understand. For example, this is the flow for my blinds:
active is depending on auto on/off, temperature and brightness. Here is the working function:
if (msg.payload.Sonne > '47000' && msg.payload.Twz >= 21 && msg.payload.ABesch === "on"){
node.status({fill:"red",shape:"dot",text:"Sonne:" + msg.payload.Sonne +" Twz:" + msg.payload.Twz +" AUTO:" + msg.payload.ABesch});
msg.payload = 100;
}else{
node.status({fill:"green",shape:"ring",text:"Sonne:" + msg.payload.Sonne +" Twz:" + msg.payload.Twz + " AUTO:" + msg.payload.ABesch});
msg.payload = 0;
msg.topic = "Sbes";
I want to get rid of all change-nodes to convert the long MQTT-string before computing into the AND-gate.
Follow the instructions I posted earlier about "copy path"
not related to your question, however here you are comparing a value against a string
eg.
msg.payload.Sonne > 47000
or if it arrives as a string
parseInt(msg.payload.Sonne) > 47000
the old phrase 'a picture is worth a thousand words' does not apply when you need to see the actual code.
What do you have the mqtt-in node's output option set to? if it is a JSON object in teh form of a string and you want to convert it to an object you should set output to auto-detect (parsed JSON object, string or buffer)
@steve-McI: when I hover to copy path, the content is just 'topic' - nothing else. Maybe it is easier to explain it like this: a string like "msg.payload.innen/WZ_Luftmonitor/temperature" leads to an error message (temperature is not defined). Anything without "/" works.
@zenof: I had chosen auto-detect (string or buffer).
Please connect a debug node(set to display the complete msg object) to the output of an mqtt-in node and show us what it looks like. (copy and paste it to a reply)
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
- Why not use
auto-detect (parsed JSON object, string or buffer)? - what version of NR and node.js are you running? (see NR startup log) \
@Werner when you click (not hover) "copy path" it will copy the path in the appropriate square bracket notation payload["innen/WZ_Luftmonitor/temperature"] automatically for you to paste into your code.
Thanks for your patience. Here we are:
Node Red v 2.2.2
Node.js: v16.16.0
{"topic":"innen/WZ_Luftmonitor","payload":25.65,"qos":0,"retain":false,"battery":0,"humidity":63.11,"linkquality":126,"temperature":25.65,"voc":85,"voltage":2800,"_msgid":"e7cec83bf577f853"}
But I used the node 'MQTT json' with property 'temperature'.
Here is a more explicit demo
You are missing out on full developer like env with Monaco editor (the code editor in the function node) and many other new nice-to-haves in V3.x ![]()
great! I have to learn so much. I didn't know the usage of square bracket notation. So I have to use variables to combine the payloads. Sure I will update to v3 first. Need some time, I will report. Thanks to all!
Looking at the message posted, is it not just msg.payload that is required?
@colin
Yes, in that single msg posted 4 up, but the overall theme is to join messages for later comparison (so I read it)
OK, understood.
