"Configuration missing" influxdb (influxdb out) error
I am trying to use a flow that works on my Raspberry Pi at my work, but not on my R-Pi at home. I expect that I have something installed wrong, or specified wrong.
When I try to deploy I get the following error message.
The workspace contains some nodes that are not properly configured:
[Flow 1] influxdb (influxdb out)
If I do confirm the deploy I get the following
9/11/2019, 9:27:03 PMnode: ffc9bd68.29f96
msg : string[21]
I don't know what it is referring to. I have tried a couple of different user/passwords.
Any suggestions on what to do with this?
You need to configure the InfluxDB Server information. Click on the pencil/pen symbol and another screen opens where you can enter the information.
Screenshot_2019-09-12_09-49-05
The flow I am using had that information populated.
I thought maybe I had a different password for that user in Influx, so I created a new user/password there and then populated in the configuration information for the Node-Red Influx node. Still the same error.
Can wrong information in the configuration cause the "Configuration missing" error message?
Did you restart node-red after installing the influx node?
No I didn't. And now I did and it works now. (I'm new at this)
Thanks.
Some nodes don't function 100% after install, node-red gives a message to restart.
