Hi there,
I'm totaly new to Node-RED and did try to create an interface to Somfy Tahoma.
- I did install the node-red-contrib-tahoma with this documentation: https://flows.nodered.org/node/node-red-contrib-tahoma
- For the Configuration I did follow this link:
https://github.com/nikkow/node-red-contrib-tahoma/wiki/How-to-create-an-Somfy-Open-API-app%3F
I do not understand point 5: "Copy and paste the Consumer Key and Consumer Secret information to your node-red installation" where do I have to copy/paste the Consumer Key and Secret in Node Red?
Meanwhile I did open Node "Tahoma Readable Element" and in the Properties section i did create a Name called Node-RED and past the API Key and API Secret. If I press the Link Node-Red to Tahoma button I can enter my Tahoma E-mail adress and password and after login I got the error message. An error occured, try again. If this issue happens again please contact technical support.
In the Node Red Debug of the tahoma node I got the issue "error: Property "servicekey" is required.
Any ideas?
Chris
