I'm getting a connect error when using email-in node
The username and password are correct and i'm using the 1.6.2 version
Any ideas ?
Thanks,
Hemdene
If you search this forum for "Gmail error" you will find threads that contain things that you can try...
So what is the error you are getting?
I'm getting Connect Error
I thought with gMail the UserID should be set to your full email address.
i.e.
some.email@gmail.com
I tried that as well and i got the same result
What does Node-RED log say?
Nothing There is no message in the debug section
And you are using an application password not your real password ?
The debug panel isn't the log. If you are on a pi type node-red-log in a terminal
I'm using my real password for each email addess i tried so far
You need to use an application password. Available via your google user security menus
