CONNECTION LOST dashboard error every 30 seconds
Running Node-Red on a Pi 3B and Chromium browser.
I am receiving external serial data from a SERIAL IN node and doing some arithmetic on the payload. Everything works flawlessly according to the debug nodes in the flow and it works fine when I initially switch to the dashboard to view the results.
But almost exactly every 30 seconds the dashboard view flashes the error "CONNECTION LOST". Everything reconnects in a second or two and all is well until after another 30 seconds when the behavior repeats.
Can anyone help me fix this?
Fred
have you some information in the Log file of the Raspian/Debian? Or what do show a top command?
I'm sorry, but I don't know how to access that
What are the things you are presenting on your dashboard? Make a screenshot ..
command Line of your Pi ?
cd /var/log
tail syslog
maybe there is something wrong
or just enter top in the comandline maybe you see something when it lost conection
The dashboard is fairly simple. The serial data comes in fairly quickly (every 250mS or so) and as I said it appears to be working in the flow.
Try to limit the data rate on the flows before the nodes of dashboard widgets. See if that helps.
Use the delay node like this.
I tried a delay in several locations. No joy.
Try stopping node-RED - node-red-stop and restart again node-red-start and watch the log.
You will probably see the point where node-RED stops & restarts, so copy the log, and paste it here so we can see what's happening.
Nothing pops up when the disconnect appears and the startup seems to be normal. I did notice that this only happens when I have the GAUGE in the group "COLUMN 2: active. Something about that is affecting this
29 Jan 14:19:29 - [info] Linux 4.19.118-v7+ arm LE
29 Jan 14:19:31 - [info] Loading palette nodes
29 Jan 14:19:37 - [info] Dashboard version 2.27.0 started at /ui
29 Jan 14:19:37 - [info] Settings file : /home/pi/.node-red/settings.js
29 Jan 14:19:37 - [info] Context store : 'default' [module=memory]
29 Jan 14:19:37 - [info] User directory : /home/pi/.node-red
29 Jan 14:19:37 - [warn] Projects disabled : editorTheme.projects.enabled=false
29 Jan 14:19:37 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
29 Jan 14:19:37 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
29 Jan 14:19:37 - [info] Starting flows
29 Jan 14:19:38 - [info] Started flows
29 Jan 14:19:38 - [info] serial port /dev/ttyAMA0 opened at 115200 baud 8N1
There seems to be a speed limit to how fast the GAUGE node can update and I was apparently exceeding that limit. When I limit the number of decimals coming into GAUGE to 2 instead of 3, it updates more slowly and the CONNECTION crash goes away.
Thanks for the responses.
Any widget with animations involved will make high rate updates very hard to handle. It is not possible to turn off the animations for ui_gauge node but you can use the artless-gauge with animations turned off. But anyway, updating the gauge with high rate makes it pretty unreadable. So rate limit is reasonable thing to do.
I imagine the main problem is running the browser on a pi3 with the node red dashboard and fairly rapid refresh rates. A pi 3 is barely powerful enough for that. You would have a much better experience if you upgraded to a pi 4.
