"id": "1c0fb3c4214105c2",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": "",
"env": []
"id": "191eb7ca.b71a8",
"type": "azureiothub",
"z": "1c0fb3c4214105c2",
"name": "Azure IoT Hub",
"protocol": "mqtt",
"x": 440,
"y": 160,
"39c7854c.56d18a"
"id": "aa561f4a.a44358",
"type": "function",
"name": "Function",
"func": "msg1 = '{\"deviceID\": \"Arduino001\", '\nmsg1 = msg1 + '\"SAK\": \"Yub6LJ9vjuPaJ4zWXCPEYr8+eRByyCUwB3h8VefIlEE=\", ' \nmsg1 = msg1 + '\"Protocol\": \"mqtt\", '\nmsg1 = msg1 + '\"Data\": { \"' + msg.topic + '\": \"' + msg.payload + '\"}}'\n\nnewMsg = { payload: msg1 };\nreturn newMsg;\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 304,
"y": 322,
"191eb7ca.b71a8",
"39c7854c.56d18a"
"id": "48115883.03fae8",
"type": "inject",
"name": "Speed",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "",
"topic": "speed",
"payload": "345",
"payloadType": "num",
"x": 121,
"y": 287,
"aa561f4a.a44358"
"id": "39c7854c.56d18a",
"type": "debug",
"active": true,
"console": "false",
"complete": "payload",
"x": 608.3400268554688,
"y": 250.47998046875,
"id": "31ae88af.f84fa",
"type": "inject",
"name": "Temperature",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "",
"topic": "temperature",
"payload": "87",
"x": 139,
"y": 323,
"aa561f4a.a44358"
"id": "fc5e350.8f97e48",
"type": "inject",
"name": "Pressure",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "",
"topic": "pressure",
"payload": "2342",
"x": 129,
"y": 359,
"aa561f4a.a44358"
"id": "f3fce0b1.76ed6",
"type": "inject",
"name": "Send Multiple Values",
"repeat": "",
"crontab": "",
"once": false,
"topic": "",
"payload": "{\"deviceID\": \"Arduino001\", \"SAK\": \"Yub6LJ9vjuPaJ4zWXCPEYr8+eRByyCUwB3h8VefIlEE=\", \"Protocol\": \"mqtt\", \"Data\": { \"AvgFlowRate\" : 500, \"FlowRate\" : 700, \"AvgStaticPressure\" : 525, \"StaticPressure\" : 518, \"AvgCasingPressure\" : 776, \"CasingPressure\" : 805, \"AvgTubingPressure\" : 609, \"TubingPressure\" : 588}}",
"payloadType": "json",
"x": 150,
"y": 180,
"191eb7ca.b71a8"
"id": "15aa66ba.d05be9",
"type": "inject",
"name": "Send one value",
"repeat": "",
"crontab": "",
"once": false,
"topic": "",
"payload": "{\"deviceID\": \"Arduino001\", \"SAK\": \"Yub6LJ9vjuPaJ4zWXCPEYr8+eRByyCUwB3h8VefIlEE=\", \"Protocol\": \"mqtt\", \"Data\": { \"Speed\" : \"25\"}}",
"x": 137.90994262695312,
"y": 110.09001922607422,
"191eb7ca.b71a8"
"id": "24956e6.952af12",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "",
"topic": "",
"payload": "{\"deviceID\": \"myiotdevice\", \"SAK\": \"dzerQ4wJGYG0DV/SetL49r3H+rFAhfdXOcFNeZWITc8=\", \"Protocol\": \"mqtt\", \"Data\": { \"Speed\" : \"25\"}}",
"x": 143,
"y": 42,
"191eb7ca.b71a8"
Dear Node Red Support Team,
I am trying to send some payload to azure IOT HUB but I am facing connection not established related problem.Are there any Permissions which need to be changed in Azure portal.Please Kindly support on this issue as soon as possible.
