Conversion Fahrenheit to Celsius - Radio thermostat set temperature
Hello!
I have a radio thermostat CT80. Its curl commands work in Fahrenheit but I want to input Celsius via a chat bot to set the temp.
Anyone know the process for doing this?
I think the input will need a template node to convert C to F....
Then the converted F result will be sent to the curl command.
Hi, have you actually tried it yet? Conversions from c to f, and f to c for that matter, follow simple formulas. You can use just about any node you like for that, from a function node to a change node (payload.temp_celsius * 1.8 + 32 as JSONata expression for example). You said you use curl for communication, so that means you can use the exec node with a curl command, or the http request node if you use an http protocol within curl.
I've used a node flow from someone else for the ct80.
All I need to do is inject the F in numerical value into a node.
So whatever does the conversion needs to output a number ie: 72
Will have a play later!
Thank you :ok_hand:
Or use the range mode to rescale the numbers appropriately
Ooh, one I wouldn’t have thought of. Thanks Dave for reminding that it exists :slight_smile:
You can also try to use my node-red-contrib-unit-converter, which supports a.o. following temperature conversions:
Good luck!
Bart
Worked a treat! Thank you
Now all i need to do is work out how to trigger the temperature till a certain time via chat bot..
Loving node red :grinning:
I'm looking at implementing your method too. I've injected a number (19) in via a payload string.
Have used a function node with:
payload.temp_celsius * 1.8 + 32;
Getting error:
"ReferenceError: payload is not defined (line 1, col 1)"
On the debug node....
I'm really green with this atm. Any tips would be useful!
Try adding ‘msg.’ before payload
Close, but that won't fix it yet:
msg.payload = msg.payload.temp_celsius * 1.8 + 32;
Or if you want to keep the original:
msg.payload.temp_fahrenheit = msg.payload.temp_celcius * 1.8 + 32;
Test flow:
Have tried the first one:
Got this in debug:
Screenshot 2020-01-04 at 23.25.39
I may have (wrongly) assumed Working with Messages was known information. What you are inserting as payload appears to be a numeric 19 value. In that case the contents of msg.payload in the function node becomes simply 19 and the description changes to msg.payload = msg.payload * 1.8 + 32;
That worked!
Will look at Working With Messages
Thanks Afelix :ok_hand:
The modern way to convert C to F or F to C is to use a range node.
C to F
-40 100
-40 212
F to C
-40 212
-40 100
[{"id":"b39e3a0a.9b8048","type":"range","z":"205d0e6a.aaefc2","minin":"-40","maxin":"100","minout":"-40","maxout":"212","action":"scale","round":false,"property":"payload","name":"C to F","x":730,"y":1100,"wires":[["6ea851ef.91e08"]]}]
