Copy local .tar file from Pi to SMB network share
Okay, I'e been struggling with this one for quite some time, I was unable to find a solution on this forum or on youtube or google. Please be aware I'm definitely not a programmer, I lear everything by doing, trial and error :slight_smile: What I want to achieve: copy a file from my Pi (running node-red) to a SMB share.
So here is the background:
My Pi is running Home Assistant and Node-red. HA makes a snapshot every night in the /backup directory, the file is called " f03caf77.tar ", this changes every night, this is for later to resolve.
I want to copy this file to my NAS, I already have the NAS setup using the palette node-red-contrib-smb. This is "working" and I can read/list files from my NAS using this flow: [{"id":"59957107.51d36","type":"inject","z":"cebf0ee4.6970c","name":"start","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":640,"wires":[["ccf04998.51c6f8"]]},{"id":"ccf04998.51c6f8","type":"SMB","z":"cebf0ee4.6970c","name":"list directory of Synology NAS","config":"95c0ac2f.4917","operation":"read-dir","path":"backups\\snapshots","path_new":"","format":"string","x":390,"y":640,"wires":[["b79fafdf.a0264"]]},{"id":"b79fafdf.a0264","type":"debug","z":"cebf0ee4.6970c","name":"debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":650,"y":640,"wires":[]},{"id":"95c0ac2f.4917","type":"smb config","z":"","name":"homenas","share":"\\\\192.168.1.250\\ha","domain":"WORKGROUP"}]
I can also list the local files in my Pi via this flow, it is using SMB to: [{"id":"dc6ac2fd.02c23","type":"inject","z":"cebf0ee4.6970c","name":"start","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":580,"wires":[["466805e2.3c9b9c"]]},{"id":"466805e2.3c9b9c","type":"SMB","z":"cebf0ee4.6970c","name":"list directory of HA","config":"83329f02.d7ea2","operation":"read-dir","path":"","path_new":"","format":"string","x":350,"y":580,"wires":[["1786ee81.1a1201"]]},{"id":"1786ee81.1a1201","type":"debug","z":"cebf0ee4.6970c","name":"debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":650,"y":580,"wires":[]},{"id":"83329f02.d7ea2","type":"smb config","z":"","name":"homeass","share":"\\\\192.168.1.222\\backup","domain":""}]
I also can write new files to my NAS from Node-red via the SMB palette , using this flow: [{"id":"4b559e51.b608a","type":"inject","z":"cebf0ee4.6970c","name":"start","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":700,"wires":[["f19405c4.616ad8"]]},{"id":"f19405c4.616ad8","type":"SMB","z":"cebf0ee4.6970c","name":"create TEST.txt file on Synology NAS","config":"95c0ac2f.4917","operation":"create","path":"backups\\snapshots\\TEST5.txt","path_new":"","format":"string","x":410,"y":700,"wires":[["1f7c412b.c9cc1f"]]},{"id":"1f7c412b.c9cc1f","type":"debug","z":"cebf0ee4.6970c","name":"debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":650,"y":700,"wires":[]},{"id":"95c0ac2f.4917","type":"smb config","z":"","name":"homenas","share":"\\\\192.168.1.250\\ha","domain":"WORKGROUP"}]
But what I cannot achieve is read the local .tar file from my Pi and save it via SMB to my NAS.
Can anyone help? I'm stuck.
Have you looked at using the Exec node and running the curl or smbclient command? That would be where I would start looking.
