Hello!
Is it possible to put all values where the topic is the same in an array.
I have a list where there are several dates and they all have to be put together where the topic is the same to make them into an array.
It's like a switch but you don't have to enter the value.
I hope that someone can help me there.
Do you want something like this?
Msg.topic = "TopicValue"
Msg.payload = [date1, date2, date3, etc]
Not really visualizing what you want here
Or do you have an array of objects and want something like this
Msg.payload = [{"Date" : Date1}, {"Date": Date2}]
Hello!
Thanks for the reply.
It should then look like this.
Hello!
If the topic or article number is different then he should make the entry in a new array.
I just found something. it should be like node-red-contrib-merge-topic.
Is there a better solution?
