Css and spacers
Good evening,
Could someone possibly tell me how to force a certain layout on a tab?
I would like to have a home icon on each tab which you can click on to go back to homepage (funnily enough).
In the attached flow I have this, but I'm can't find a way of forcing everything else to start one row below.
Well, I can do this by adding another group and making it very wide to force everything down, but this seems a bit scrappy.
As ever, any help would be much appreciated.
Kind regards
Paul
flows (7).json (6.9 KB)
I'm not sure if this is what you are after, but you can move widgets around with the layout editor.
I made the Home button a fixed size 1x1. You could put it top left in the dimmer test group too.
Untitled 1
Thanks v much, perfect
