CSS Challenge: Water Tank SVG Mask
Hey All, had a play this morning in adding a "Water Tank" to the ui-gauge in Dashboard 2.0 (having also recently added a Battery Gauge) - you can see the PR (and a little video demo) here
The challenge I've got is applying an SVG clip-path to the text that considers both the waves and the general fill. I've currently got them as two entities, thinking I may need to modify the SVG wave to animate in height as a single entity, rather than having the <rect> and the <path>
If anyone fancies a play before I come back to this on Tuesday, please feel free to fork/PR! All help is very much appreciated.
How do we install these [future] gauge types?
npm install @flowfuse/node-red-dashboard@next
npm error code ETARGET
npm error notarget No matching version found for @flowfuse/node-red-dashboard@next.
You need to clone/install the source from GitHub, as its not published to npm anywhere at the moment
Thanks for the link.
It looked complicated but I tried.
Unfortunately npm run build died out of memory (a Pi 4 with 2GB).
I'd expect to not need that much, but the development version is certainly more computationally expensive than our released builds
I uninstalled zram (which uses some memory as RAM based swap space), then it compiled.
To get the water tank you'll need to switch to the 1192-gauge-water-tank branch linked to the PR, then npm run build and it'll be in there.
Anytime you're changing the source CSS/Vue, just need to re-build, and itll update on your Dashboard.
:+1:t4:
I am initially looking at the battery gauge with the aim of making the colour continuously variable
It might be useful to mention @hotNipi, unless he is currently buried somewhere partially intoxicated with alcohol on a beach of some tropical island :palm_tree: :parasol_on_ground: :clinking_glasses:
I'm nearby. Vacation just started. This means grandchildren and that long list of activities which I refused to read to the end. So the CSS has currently priority order Number.MIN_SAFE_INTEGER
Spent another 6-7 hours on this, finally got it working, and the wave mask then makes the number very difficult to read - abandoning and just rendering in black :smiley:
the wave mask was cool looking..... but visibility trumps cool
