When I try to save the layout editor of dashboard 2.0 i get the error Request failed with status code 500.
How can I solve this?
How is your node-red setup & how is it served? (home assistant / docker?, embedded device?, etc)
Any special changes to how node-red and dashboard are served (specific settings.js tweaks etc around http admin endpoint etc)?
Is it behind a reverse proxy (haproxy/nginx/etc)?
Also when I connect to the Nodered docker container directly via port 18801 I get the 500 error while saving the edited dashboard.
Headers:
Response:
{"error":"Invalid URL"}
Payload:
{"dashboard":"16f8dcba58e35d0c","page":"53162992b7e393dd","key":"q8vw8tft9z8","changes":{"groups":[{"id":"df52653d2a483c2d","name":"Binnen","page":"53162992b7e393dd","width":"12","height":1,"order":1,"showTitle":false,"className":"","visible":"true","disabled":"false","groupType":"default","_users":["2967f5033b8d7ce8","732f637a49d77bcb","7dd3e1a547247c5e","d47bd5ca44d0f0c7","1d895e4e4f1f3914","ee56cf721cbfdfc6"]},{"id":"2938a2512d900e16","name":"Buiten","page":"53162992b7e393dd","width":"12","height":1,"order":2,"showTitle":false,"className":"","visible":"true","disabled":"false","groupType":"default","_users":["6f6887dee229c598","4879e828e4848b21","06ef2b12e7af69a3","5215d2e4edc21635"]}],"widgets":[{"id":"2967f5033b8d7ce8","type":"ui-slider","z":"88a13305.b12af","group":"df52653d2a483c2d","name":"","label":"Plafond Achter","tooltip":"","order":1,"width":"3","height":"2","passthru":false,"outs":"all","topic":"topic","topicType":"msg","thumbLabel":"always","showTicks":"always","min":0,"max":"100","step":"10","className":"","iconPrepend":"","iconAppend":"","color":"","colorTrack":"","colorThumb":"","showTextField":false,"enabled":true,"visible":true,"class":""},{"id":"732f637a49d77bcb","type":"ui-slider","z":"88a13305.b12af","group":"df52653d2a483c2d","name":"","label":"Plafond Achter 1","tooltip":"","order":2,"width":"3","height":"2","passthru":false,"outs":"all","topic":"topic","topicType":"msg","thumbLabel":"always","showTicks":"always","min":0,"max":"100","step":"10","className":"","iconPrepend":"","iconAppend":"","color":"","colorTrack":"","colorThumb":"","showTextField":false,"enabled":true,"visible":true,"class":""},{"id":"7dd3e1a547247c5e","type":"ui-slider","z":"88a13305.b12af","group":"df52653d2a483c2d","name":"","label":"Plafond Achter 2","tooltip":"","order":3,"width":"3","height":"2","passthru":false,"outs":"all","topic":"topic","topicType":"msg","thumbLabel":"always","showTicks":"always","min":0,"max":"100","step":"10","className":"","iconPrepend":"","iconAppend":"","color":"","colorTrack":"","colorThumb":"","showTextField":false,"enabled":true,"visible":true,"class":""},{"id":"d47bd5ca44d0f0c7","type":"ui-button","z":"88a13305.b12af","group":"df52653d2a483c2d","name":"","label":"Spiegelkast","order":5,"width":"3","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"blue","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","enabled":true,"visible":true,"class":""},{"id":"1d895e4e4f1f3914","type":"ui-button","z":"88a13305.b12af","group":"df52653d2a483c2d","name":"","label":"Spot","order":6,"width":"3","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","enabled":true,"visible":true,"class":""},{"id":"ee56cf721cbfdfc6","type":"ui-button","z":"88a13305.b12af","group":"df52653d2a483c2d","name":"","label":"Sierlamp","order":7,"width":"3","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"blue","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","enabled":true,"visible":true,"class":""},{"id":"4879e828e4848b21","type":"ui-button","z":"88a13305.b12af","group":"2938a2512d900e16","name":"","label":"Schutting 2","order":1,"width":"3","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"blue","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","enabled":true,"visible":true,"class":""},{"id":"6f6887dee229c598","type":"ui-button","z":"88a13305.b12af","group":"2938a2512d900e16","name":"","label":"Schutting 1","order":2,"width":"3","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"blue","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","enabled":true,"visible":true,"class":""},{"id":"06ef2b12e7af69a3","type":"ui-button","z":"88a13305.b12af","group":"2938a2512d900e16","name":"","label":"Schutting 3","order":3,"width":"3","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"blue","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","enabled":true,"visible":true,"class":""},{"id":"5215d2e4edc21635","type":"ui-button","z":"88a13305.b12af","group":"2938a2512d900e16","name":"","label":"Voortuin","order":4,"width":"3","height":"1","emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"blue","textColor":"","iconColor":"","enableClick":true,"enablePointerdown":false,"pointerdownPayload":"","pointerdownPayloadType":"str","enablePointerup":false,"pointerupPayload":"","pointerupPayloadType":"str","enabled":true,"visible":true,"class":""}]}}
