I made a gauge with a tank level. When it is 100%, the image looks almost empty.
Is this correct?
Is this correct?
Can't confirm. Try to clear browser cache and maybe restart node red ...
No. Could you export a minimal flow that demonstrates this and raise an issue please.
Found it! It is a browser issue.
Firefox it is not working. (did also a test in private mode)
Chrome it is working, perfect!
Is it possible to make it work with Firefox?
The battery gauge is working in both browsers
"id": "2187465d8f29d3be",
"type": "tab",
"label": "TEST",
"disabled": false,
"info": "",
"env": []
"id": "230410bb50a5052e",
"type": "ui-gauge",
"z": "2187465d8f29d3be",
"name": "test",
"group": "6ce8a69ad97aa835",
"order": 2,
"width": 3,
"height": "6",
"gtype": "gauge-tank",
"gstyle": "needle",
"title": "test",
"units": "units",
"icon": "",
"prefix": "",
"suffix": "",
"segments": [
"from": "0",
"color": "#a8f5ff"
"from": "15",
"color": "#55dbec"
"from": "35",
"color": "#53b4fd"
"from": "50",
"color": "#2397d1"
"min": 0,
"max": "100",
"sizeThickness": 16,
"sizeGap": 4,
"sizeKeyThickness": 8,
"styleRounded": true,
"styleGlow": false,
"className": "",
"x": 330,
"y": 120,
"id": "2bdab544e314d248",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "50",
"payloadType": "num",
"x": 170,
"y": 100,
"230410bb50a5052e"
"id": "68c0c861e6798cdb",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "100",
"x": 150,
"y": 160,
"230410bb50a5052e"
"id": "da7175dcf2443693",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "10",
"x": 170,
"y": 60,
"230410bb50a5052e"
"id": "6ce8a69ad97aa835",
"type": "ui-group",
"name": "Ontharder zout stand",
"page": "ba8733e4b7f8ed68",
"width": "3",
"height": "6",
"order": 1,
"showTitle": false,
"className": "",
"visible": "true",
"disabled": "false"
"id": "ba8733e4b7f8ed68",
"type": "ui-page",
"name": "Status diversen",
"ui": "07d9e68410f8668f",
"path": "/StatusDiv",
"icon": "home",
"layout": "grid",
"theme": "58232a5d443a2893",
"order": 2,
"className": "",
"visible": true,
"disabled": false
"id": "07d9e68410f8668f",
"type": "ui-base",
"name": "Dashboard",
"path": "/dashboard",
"includeClientData": true,
"acceptsClientConfig": [
"ui-notification",
"ui-control"
"showPathInSidebar": false,
"showPageTitle": true,
"navigationStyle": "default",
"titleBarStyle": "default"
"id": "58232a5d443a2893",
"type": "ui-theme",
"name": "Theme MMMM",
"colors": {
"surface": "#242424",
"primary": "#0094ce",
"bgPage": "#535353",
"groupBg": "#d3d3d3",
"groupOutline": "#cccccc"
"sizes": {
"pagePadding": "12px",
"groupGap": "12px",
"groupBorderRadius": "4px",
"widgetGap": "12px",
"density": "default"
Which version of FF?
Installed latest FF.Changes the height from 0 to somewhere about 20% and then only the color changes but not the height of the liquid.
No errors in console...
FF version 130.0 Mobile version and windows version. Both same issue.
is this a bug now?
If this is still not working for you could you submit an issue please at Issues · FlowFuse/node-red-dashboard · GitHub
Include your flow in the issue.
Link to the issue here so others interested can follow it.
