Dashboard 2.0 Project - Live Demo Dashboard
Hi All, wanted to make you aware of a new asset we've made available: Dashboard 2.0 Interactive Docs
On this Dashboard you'll find interactive examples for all of our published widgets, with example flows, and a bit of help documentation too.
You can also navigate to these interactive demos from our documentation from the new "Try Demo" buttons:
Thanks to @gayanSandamal for his work on the interactive docs!
The bar chart example threw me for a bit because it looked like when you used a slider it would change the bar associated with it, then start changing the other bar.
I finally realized that what was changing is the scale of the graph as the value goes up and down.
Good point - @gayanSandamal maybe worth setting yMax on those charts to alleviate this?
Yes, setting a max y will helps this. I will have a look on this
Welcome @gayanSandamal and a nice Documentation/Examples.
One question I do have, is it possible to change the colour of a button yet so that we can indicate it's state (say On/Green or Off/Red)?
It certainly is: Button ui-button | Node-RED Dashboard 2.0
Thank you, last time I looked that property wasn't available.
@mudwalker , thank you and sorry for the late reply. As @joepavitt mentioned, you can set the button background, text, and icon colors using RGB, HEX, or any other colour format. I hope the Dashboard 2.0 documentation helps with that.
