Dashboard 2.0 table set custom CSS
I used the table node from dashboard 2.0 and find it very easy to use.
The only problem is that I use it on some production screens, and that the font is much too small to read from distance. Can you make changes to the layout of the table through CSS, or do you need than to use the template node to build an html table?
I find it really confusing what you can do with what :frowning: . I have building the whole day at a simple table switching between a template node and a table node. The table node is much quicker, and I couldn't image that you cannot set any custom layout on it through CSS. But i wasn't able to find any good example on this.
If you make it clear from the post title that you are looking for help with CSS then the right person will probably see it and help. You can edit the title by clicking the pen icon beside it.
