@LauCaen Welcome to the forum!
With the information you have provided the answer is NO.
- How long does it take to disappear?
- Is the Pi connected to a monitor that you are seeing the dashboard on? or are you using another device to display the dashboard?
- Does anything else happen when the dashboard disappears?
- Are you running in a Docker image?
- What version of Node-RED and node.js are you running (you can find this in the startup log)
- since you can recreate it, can you provide the plow and the steps that cause it to disappear?
code goes here
icon.
