iijan
1
having bit of an issue trying to display a line chart using stored data,. here is the payload i am sending to the dashboard ui chart node
{"label":"label","data":[{"x":1589785353387,"y":74},{"x":1589785371831,"y":74},{"x":1589785380067,"y":74},{"x":1589785440072,"y":74},{"x":1589785500067,"y":75},{"x":1589785561766,"y":77}],"series":"Humidity"}
what am i doing wrong?..
Colin
2
It doesn't look much like the format described in the docs (under Stored data). Not nearly enough square brackets about the place.
iijan
3
thanks! it was the square brackets!
nested array
