How a line chart shows a payload of 700 data separated by comma?
I have a payload of 700 data separated by comma. I would like to show them in a line chart. How should I set the chart node? Note: The chart will be updated if the new payload comes in.
Thx
8526,7846,7855,7879,7649,7600,7927,7772,7411,7600,7689,7659,7760,7826,7608,7821,7866,7998,7812,7748,7698,7810,8205,8111,7702,7859,8134,7976,7539,7771,7960,7999,8082,7815,8914,8525,8301,8239,7988,8091,7889,7929,7778,7905,7804,7797,7978,8002,7863,8014,8204,8576,9352,10188,10025,9453,9046,9498,9274,9357,9381,9301,8897,8581,8505,8657,8723,9035,9658,9808,9191,7364,7486,8004,8098,5932,7467,8875,8422,8291,8057,7370,6290,5439,5404,5548,5792,6144,6554,6559,7148,6096,5595,5842,5420,5161,4907,4797,4907,4875,4735,4383,4348,4573,5383,6869,8300,9661,10365,10992,11374,11211,11143,12114,12834,12863,23061,33937,16510,17189,11958,8871,7758,6992,12194,14164,12654,11075,9977,9885,9455,9855,10650,11235,10975,10513,10576,10414,11024,12271,10813,7878,10520,10025,9022,8569,8262,7554,6623,6069,6000,6822,7802,8718,8802,8012,6150,9654,9148,10577,11737,13397,14372,15947,16254,16959,17716,18130,17792,26737,34973,29777,21057,26178,22241,16104,19420,15130,11475,8212,8963,8547,8392,8976,9315...
Line chart is a line, drawn between points. Point is two-dimensional object. {x;y} You have only one dimension. Let's say those numbers represent value, which most commonly goes to vertical axis y but you are missing the horizontal component x (most commonly the time)
Line chart can be created only if you add some value for x, every next a bit bigger than previous.
For live data, if new value is sent to chart, the x (timestamp) is created automatically so you can send only the value. But for historical data, you'll need to store values with timestamps.
What the output payload should be?
Thanks.
Maybe you'll get the answer from this document: node-red-dashboard/Charts.md at master · node-red/node-red-dashboard · GitHub
I have made the payload to be this (just 10 data for testing). But I am not sure the setting in the line chart node. Thanks
"[{"data":[{"x":2,"y":10005},{"x":3,"y":9223},{"x":4,"y":9007},{"x":5,"y":8522},{"x":6,"y":8489},{"x":7,"y":9283},{"x":8,"y":8902},{"x":9,"y":8790},{"x":10,"y":8403},{"x":11,"y":8036}],"labels": [""]}]"
The debug tab says, that data has bad format.
Correct will be
msg.payload = [
        "series": ["A"],
        "data": [
            [{"x":2,"y":10005},
            {"x":3,"y":9223},
            {"x":4,"y":9007},
            {"x":5,"y":8522},
            {"x":6,"y":8489},
            {"x":7,"y":9283},
            {"x":8,"y":8902},
            {"x":9,"y":8790},
            {"x":10,"y":8403},
            {"x":11,"y":8036}
        "labels": [""]
return msg
I have made the same format but still can not show the line.... Sorry to bother you but I wonder if my chart node setting is correct. Thx
Thanks.
[{"series": ["AccT"],"data":[[{"x":2,"y":9296},{"x":3,"y":7829},{"x":4,"y":7880},{"x":5,"y":7660},{"x":6,"y":7921},{"x":7,"y":7657},{"x":8,"y":7891},{"x":9,"y":7813},{"x":10,"y":7876},{"x":11,"y":7909}]],"labels": [""]}]
Better format to this (Same)
"series": ["AccT"],
"data":[
[{"x":2,"y":9296},
{"x":3,"y":7829},
{"x":4,"y":7880},
{"x":5,"y":7660},
{"x":6,"y":7921},
{"x":7,"y":7657},
{"x":8,"y":7891},
{"x":9,"y":7813},
{"x":10,"y":7876},
{"x":11,"y":7909}
"labels": [""]
With your settings I get this
msg.payload is string. That's why you don't get anything.
It should be an array.
msg.payload = [
        "series": ["A"],
        "data": [ .....
You can simply put a function node before your chart with
msg.payload = JSON.parse(msg.payload);
That will do the conversion
Though probably better to build it as an object in the first place. You can convert your input (assuming that is a string too) into an array by adding a [ on the front and a ] on the end and feeding it through a JSON node. Then you can build your payload much easier that using string manipulation, which I assume you have been doing.
It is working now.
Thanks all. :>
chart_working
