i wonder if there is a way to get a fixed order to the main menu. At the monent the order changed from time to time. I guess everytime when i changed something on the layout.
And is there also a way to implement sub-menus in the main menu?
Regards
gerribaldi
Hi @gerribaldi,
That is not possible with the standard menu. However in my readme page you can see how @Paul-Reed has found a workaround via the node-red-contrib-ui-contextmenu node...
Bart
Thanks for the link - i will check and try it.....
Regards
Is there a way to make a fixed order in the main menu?
