hello all
I came across with a web page that is clergy made with node-red. It has some interesting features, that I presume are not standard .
Please relate to the print screen
A) it has a name and logo
B) the menus have sub menus and can be collapse
I would appreciate how we could replicate this nice features
thank you all
Hi @JoseGodinho
when you say its clearly made with Node-RED, what leads you to believe that? From the screenshot, it could be a 'normal' angular app using the same material design that Node-RED Dashboard does - in which case the sort of menu/submenu would be easy to do as it won't have the same constraints Node-RED Dashboard has.
'View source' of the page will mention Node-RED if it really is a customised Node-RED dashboard page.
Hi @knolleary.
After checking the source I find no mention to node red.
thank you for your support
Kind regards
I'm a big NodeRed fan since 1 year. I wonder if it is possible to get sub-menus on the main left menu, I haven't found how to do it.
Have I missed it or is that not possible.
The solution for the moment is to display a page with buttons as sub-menus. A little less practical though.
Thank you in advance for your insights.
/Jean-Luc
