I control my openhab2 with Nodered.
Now I have the following problem:
I have created a dashboard with some "numeric inputs" to set the temperature of the heater.
If I now want to set the temperature from 22.0 to 17.0 degrees, I have to press the button 10 times to decrease and so 10 values are passed to the thermostat. However, the heating controller or homegamer can not cope with this and will be switched to "OFFLINE" in the openhab. When I wait a bit between values, everything works.
How can I always take the last value of the "numeric input" and only pass this to Openahab and not the whole chain of values?
For this I have created the following Dashboard:
[{"id":"63d7acc1.496704","type":"openhab2-in","z":"52461ac0.04760c","name":"","controller":"ce8959a.db84d28","itemname":"Stube_Heizung_Seite_SetTemperature","x":224,"y":319,"wires":[["2ed8fd74.02d80a","e1ee89f5.515518"],[]]},{"id":"f1dab60c.f0f9b8","type":"openhab2-out","z":"52461ac0.04760c","name":"","controller":"ce8959a.db84d28","itemname":"Stube_Heizung_Seite_SetTemperature","topic":"ItemCommand","payload":"","x":1137,"y":365,"wires":[[]]},{"id":"2ed8fd74.02d80a","type":"ui_numeric","z":"52461ac0.04760c","name":"","label":"Stube","group":"13405f4.9b098a1","order":0,"width":0,"height":0,"passthru":false,"topic":"","format":"{{value}}","min":"4","max":"26","step":"0.5","x":621,"y":364,"wires":[["3877c5a4.5e7f42"]]},{"id":"3877c5a4.5e7f42","type":"delay","z":"52461ac0.04760c","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":854,"y":365.5,"wires":[["5a3e783f.1b9598","f1dab60c.f0f9b8"]]},{"id":"e1ee89f5.515518","type":"ui_gauge","z":"52461ac0.04760c","name":"","group":"13405f4.9b098a1","order":0,"width":0,"height":0,"gtype":"donut","title":"Temp","label":"Grad","format":"{{value}}","min":0,"max":"30","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":618,"y":305,"wires":[]},{"id":"5a3e783f.1b9598","type":"debug","z":"52461ac0.04760c","name":"Dashboard","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":987,"y":263,"wires":[]},{"id":"ce8959a.db84d28","type":"openhab2-controller","z":"","name":"openhab2","protocol":"http","host":"localhost","port":"8080","path":"","username":"","password":""},{"id":"13405f4.9b098a1","type":"ui_group","z":"","name":"Heizung","tab":"52d72958.8f4ad","disp":true,"width":"6","collapse":false},{"id":"52d72958.8f4ad","type":"ui_tab","z":"","name":"myHome","icon":"dashboard","order":1}]
Thank you.
greeting
Hermann
