Dashboard on port 8123 and not in the 1880
Good morning.
The addressing to port 1880/endpoint/ui is not done correctly in the last update.
When clicking on the icon, it directs to 8123/endpoint/ui.
Can you fix it? Or is it just me?
Thank you and forgive my intrusion in the forum.
Or can you help me and tell me where I can change that address myself.
Daniel.
What do you have the uiPort set to in settings.js?
What version of Nod-RED are you running?
What update are you referencing?
What icon are you clicking on?
no one but you know this information
8123 being the default port for Home Assistant, I would suspect you are using it. If that is the case, it is probably better to ask for help on HA forum.
Sorry, but I dont know where is the position of the setting.js. I have a Home Assistant and node red with a addon.
The actual version is 18.1.1
The icon is at the top right, it is a folder with a curved arrow.
In the last update it stopped redirecting correctly.
Where can I find the setting to change the port?
Thanks alot.
Thanks. I put the same post in HA
Daniel.
