Dashboard url in the node dashboard widget no longer working
I bookmarked the dashboard so I can still get to it, but the dashboard widget in Node Red is pointing to the URL without the socket ID on the end, and when I navigate there by clicking the link I get an http 404 (not found error).
Now, as I said, I have a workaround, but I'm not sure how long the bookmarked page will work...
Is there some way to fix this, or do I need to back up my flows and reinstall?
PS, running node red addon to home assistant, latest/greatest for both, and dashboard
Why wouldnt it work?
The only reason i can think of is if you are accessing the Dashboard from another system from where Node-red is installed and the ip of the NR server changes.
The way you access the Dashboard is
  1. if its with a browser on the same system as node-red :
    http://localhost:1880/ui
  2. another system on same network http://<node-red-server-ip>:1880/ui
no need to bookmark the socket part
dash_widget
dash_fail
So I'm not really typing or configuring in a url when it doesn't work, I'm clicking on the widget supplied by node red dashboard, and I get a 404 (see above). This is new behaviour and why I think my install
of node red dashboard maybe has an issue - happened after a restart.
homeassistant .. sorry missed that part. i dont know anything about it
obviously there something wrong with the button link
in the url it says port 8123 ?
if you try http://<yourhomeassistantip>:1880/endpoint/ui/ ??
does that work ?
Boom!
It was the port, for some reason it's using home assistant port (8123).
Fixing the port to 1880 worked!
Now, just gotta figure out what's the deal with the widget, but I can live with it. Maybe next update will fix it...
Thanks!
