Which is the command to delete nodes in Windows Node-red?
If you mean uninstall you can use the manage palette option in the menu on any operating system
but I put the azure iot hub node and now it doesn´t let me to start node red, so I want to unistall that from the CMD
It depends how you installed it...
It should be npm uninstall name-of-node in your .node-red directory
i have installed from the manage palette
If you are on node-red v0.20.x and had read the blog posting for Node-RED: Version 0.20 released you might remember the new --safe parameter.
You should still be able to npm uninstall as @ukmoose said.
- Open a command prompt
- Cd to your node red folder
npm uninstall exact-name-of-node
Incase it's installed globally, then npm -g uninstall exact-name-of-node
