I want to import a json file into node-red dynamically instead of doing it manually, and I tried to use curl command 'curl -X POST http://localhost:1880/flows -H "Content-Type: application/json" --data "@myflow.json"', I successfully saw the new flow inside but it overwrote all my previous flows, also the /data/flows.json has been overwritten, however, I would like to add the new flow after the previous one, is it possible to do this?
