Display PDF file on Dashboard
Hi everyone,
I'm trying to display a local pdf file on the dashboard (the file path is C:\Users\Silvia\Downloads\test.pdf);
I've tried using a template node with this code on it, as seen on other posts:
<div>
    <a href="file:///C:\Users\Silvia\Downloads\test.pdf" type="application/pdf"><span>Link</span></a>
</div>
I've also tried different variations of it, like using iframe or embed, but nothing works :frowning:
If I copy this: file:///C:\Users\Silvia\Downloads\test.pdf on the browser tab then it works.
However, if I copy the same path onto the dashboard link, it doesn't work.
Any ideas about what I'm doing wrong, please?
Additional info:
  • Running Node-Red on Windows 7 (hosted and accessing it locally -- it will eventually move to a Linux server)
  • Node-Red version v0.18.4
  • Node-Red-Dashboard v2.9.6
  • The inject and the ui template node:
[{"id":"337fba3e.8f9676","type":"inject","z":"f07539be.1a42e8","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":570,"y":200,"wires":[["eef3f4ba.042618"]]},{"id":"eef3f4ba.042618","type":"ui_template","z":"f07539be.1a42e8","group":"c7449154.b17ef","name":"","order":0,"width":0,"height":0,"format":"<div>\n <a href=\"file:///C:\\Users\\Silvia\\Downloads\\test.pdf\" type=\"application/pdf\"><span>Link</span></a>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":740,"y":200,"wires":[[]]},{"id":"c7449154.b17ef","type":"ui_group","z":"","name":"Default","tab":"b34fbabd.5b2438","disp":true,"width":"6","collapse":false},{"id":"b34fbabd.5b2438","type":"ui_tab","z":"","name":"Test","icon":"dashboard"}]
Thanks :slight_smile:
[EDIT]:
Another approach I've tried is to use a http request, like described here: https://stackoverflow.com/questions/40957970/node-red-upload-attachment-over-http
... but still no joy!
This is related to browser security. a file:// tag is not allowed to point to a local file.
If you check the web inspector>console it will state: not allowed to load local resource
Solution is to make the file available on a (local/remote) webserver.
Thanks for your reply @bakman2
For anyone else in this situation... I've got round this problem using the Web Server for Chrome extension
Hi.
Thank you very much Silvia for sharing how you have solved your problem, in my case with your information I have been able to solve how to show a pdf from the dashboard.
