Display text in a svg graphic
Hello Folks,
i need your help for a new Flow. I want to show a Heating buffer with its temperature state. I found the most solution in this thread . Now i want to display the values of the four temparature sensors i have. I can add text in the svg box:
<text x="10" y="50" font-family="Verdana" font-size="15" fill="black">{msg.payload}</text>
But what syntax do i need to see the values of the sensors?
Thanks in advice, Markus
@markush,
I think this example flow on my readme page should get you started.
Good luck!
Bart
@BartButenaers Thank you :+1: this should work, I will test it.
