Docker NR & ttyUSB0 Permission denied
Hello, since a few days I test NR Docker.
I use Portainer.io to manage my containers. It's quite simple.
Now I want to be able to use the serialport node to read what is on the USB port (RFlink card) of my OrangePi.
So I found the place where to bring up the ttyUSB0 port in the container, but there is still a problem of access rights. I don't know how and where to add the node-red user to the diaolout group or maybe launch the container as root?
Would you have any suggestions, solutions to help me.
Thanks to all !
Inside the NR container:
Inside Portainer.io
On the editor
The whole stack
You can add node-red to the dialout group by adding the following commands in your node-red dockerfile
USER root
RUN addgroup node-red dialout
USER node-red
maybe you also need to check if your dialout group exists in your docker container an is having the same group ID as your host machine.
I read in the documentation that you have to launch the container with the addition of the user to the dialout group,
but I can't find the way to make it work under portainer.io
Syntax error ?
this is what i see under the Pi for USB0
With portainer GUI, we don't use dockerfile :upside_down_face:
i tried to translate this specific command with no luck actually
What is your actual command to run the container ?
Sorry, I don't know, because everything is hidden by the portainer.io GUI.
Here is the container log, it seems that the additional command is taken into account, at least I have the impression.
I tried to change the User by root, so I lost my flow but still the access problem.
The --group-add option is a docker run option and not a node.js option.
You should be able to specify it somehow when creating a new container.
you can always start (run) the container from outside portainer - and then manage it from there (and then maybe see where is sets/saves that extra option)
yes indeed, I will try to understand the dockerfile commands and run it by hand.
I may ask the question in the portainer forum.
I looked in the directory used by portainer, it seems that it uses its DB to store its configuration, no traces of a readable file :pensive:
Did you use this tool or do you pass the commands by hand?
How do you add node red in portainer? Do you specify a docker image?
The image is: nodered/node-red (it takes the latest)
The process is:
  1. create the volume:
Add Network if needed:
  1. Add container:
and fill the yellow fields
Under Volume:
Under Network :
Under Runtime
And press Deploy and that's it
So one solution would be to build your own image with the appropriate modifications.
I'll do some digging, I have a feeling it's just a syntax problem in the Command field.
I can see in the container log that the order is placed but it is malformed compared to what I circled in red
build my container, probably the next step :thinking:
For now I want to stay with the standard
I don't think that is your problem.
The command field allows you to specify the docker CMD for your container.
What you need is a way to specify docker run options (more particularly the --group-add option).
I understand that you have created your container by adding the container via portainer.
I did have a quick look and I don't think it is possible to specify docker run options via portainer.
You can of course create an image from a simple container that is adding the dialout group for node-red user (see my earlier post) and select this image in portainer when adding a new container.
Yes, i did.
I just asked the question in the portainer.io forum.
If I get a positive answer, I'll come back to put it on my post
I just found this possibility into Portainer.io.
This could be the place to write the orders used when creating a container
What you mention there is the possibility to use a docker-compose file, but I don't think you can add a group to node-red via a docker-compose file.
You need to create a simple image that sets the permission.
So you need to create a Dockerfile with following contents on the host machine where portainer is running.
FROM nodered/node-red
USER root
USER node-red
You can a build an docker image based on the above Dockerfile using below command (should be run in the same folder where you have created the above Dockerfile)
[root@nuc-jan test]# docker build -t node-red-with-dialout-permissions .
Sending build context to Docker daemon  2.048kB
Step 1/4 : FROM nodered/node-red:1.2.9-12
 ---> 9772fc53c59f
Step 2/4 : USER root
 ---> Using cache
 ---> f51e7cd902b0
Step 3/4 : RUN addgroup node-red dialout
 ---> Running in 15b6a066db67
Removing intermediate container 15b6a066db67
 ---> dfcc57c65d21
Step 4/4 : USER node-red
 ---> Running in 407d4e0100a9
Removing intermediate container 407d4e0100a9
 ---> 0e44d20e1653
Successfully built 0e44d20e1653
Successfully tagged node-red-with-dialout-permissions:latest
Now you can deploy a container using image node-red-with-dialout-permissions:latest in portainer as you used to do.
I have tested this and it works for me as you can see in screenshot below:
It does indeed work. Great :smiley:
You have to do things on the command line. as often
I'm going to get an arduino to connect to the USB and see if there is a real dialog that goes back to NR.
I'll give you a feedback as soon as I've done the manipulation.
Yes, it works.
Except that the name USB0 has become ACM0.
Changed this in the container and the flow, Et voilà !
I really appreciate your help in moving forward on the docker path.
So, if I understand correctly, I can create an image with the nodes I need in my flows in the same way.
One question, what about the configuration-flows-credentials files.
Will they be included in the image or will they be left separately ?
The ones in my case /data that physically point to /var/lib/docker/volumes/node_red_user_data/_data ?
