I have a Windows System.
Inside the Windows System, I have Virtual Box with Ubuntu
Inside the Ubuntu, I have installed Node-Red and SQL Server as dockers.
While being inside the Ubuntu,
I am able to work with Node-Red via localhost:1880
I am able to work with SQL-Server via localhost:1433 or 127.0.0.1 or 127.17.0.03:1433 or 127.18.0.3:1433 using the Azure Data Studio for Linux.
Considering the previous status, Node-Red & SQL Server are up and running, now i am trying to write from Node-Red to SQL Server table.
I have tried to use the MSSQL Node from node-red-contrib-mssql-plus:
using localhost:1433, I am getting: Failed to connect to localhost:1433 Could not connect (sequence)
using 127.0.0.1:1433, I am getting: Failed to connect to 127.0.0.1:1433 connect ECONNREFUSED 127.0.0.1:1433
using 127.17.0.3:1433, I am getting: Failed to connect to 127.17.0.3:1433 connect ECONNREFUSED 127.17.0.3:1433
using 127.18.0.3:1433, I am getting: Failed to connect to 127.18.0.3:1433 connect ECONNREFUSED 127.18.0.3:1433
I tried both with SA and with a user I created, both are working via Azure Data Studio
In addition, I have tried to add a bridge between these two containers and connect them in this new network.
Also noticed that if I try with 14XX I get the same error, and if I try with SQL stopped again I get the same error. Security issue? But why Azure studio have not a problem?
What I am missing?
----Update----
If I configure the mssql-node with the name of the container of the MSSQL is working.
- Hostname: sql1
- Port: 1433
Still not sure why its not working with ips
