hi Guys,
i need to know that the node red supports 1)dhcp and 2)PLC ???
hi Guys,
Node-RED doesn't do anything with DHCP ... that is up to the operating system's networking to sort out your network connection
There are various nodes available for different types of PLC available on flows.nodered.org - you'd have to see if there is one for your particular device type
hi knolleary
@knolleary can we coustmizse the node read and implement it in the my webpage ..so when i open my webpage should i install node red again & again. can u help help me with this..
how can we merge the webpage along with the node red in my webpage. so that it should work without installing the node red everytime.
thanks
If your web site is a node express app you can embed Node-RED directly https://nodered.org/docs/embedding . or otherwise you just use an iframe.
thanks sir
