Does workspace == all the nodes on the current tab?
.. or all the nodes on all tabs?
So long since I've used Full , I've forgotton what it does but I want to re-deploy all the nodes on just the tab I'm working on - don't want to affect other working flows on other tabs, so asking before I press it!
full - is everything - stops the runtime and restarts it.
Sounds like you want modified flows.
Modified doesn't seem to re-deploy all the nodes in my current tab
Specifically - I've got a trigger node showing blue "in use" (as I call it) that doesn't clear when I change another node on the tab and re-deploy using Modified Flows
in this case tab != flow :-).... something in that actual "path" (or flow) has to be modified - like one of those injects or function... If it's not wired into that "flow" it doesn't count.
Ta for confirming info - that was what I thought Modified did.
I was just having difficulty in clearing the blue dot so was looking at the Full option
But I think I was just seeing some glitch in the matrix as it clearing now every-time I modify a connected node :slight_smile:
